When using nested FieldLayouts inside a XamDataGrid, is it possible to use different styling for the parent layout and the nested layout?
Given the structure of the xaml, I'm not sure how I'd accomplish this. The xaml structure of my window is below.
Can I style the two FieldLayouts? The Fields? A snippet of example code would be really helpful.
<igDP:XamDataGrid Name="grid" Style="{StaticResource DefaultGrid}">
<igDP:XamDataGrid.FieldLayouts>
<igDP:FieldLayout Key="myParentRow">
<igDP:FieldLayout.Fields>
<igDP:Field Name="Name"/>
<igDP:Field Name="DetailRows" Visibility="Hidden"/>
</igDP:FieldLayout.Fields>
</igDP:FieldLayout>
<!-- Can I style this sub-grid differently than myParentRow above? -->
<igDP:FieldLayout ParentFieldLayoutKey="myParentRow">
<igDP:Field Name="Foo"/>
<igDP:Field Name="Bar"/>
</igDP:XamDataGrid.FieldLayouts>
</igDP:XamDataGrid>
Thank you for your post. I have been looking into it and I can say that every FieldLayout has FieldSettings and FieldLayoutSettings properties where you can set Styles, which will be used in that particular FieldLayout only. Here it is shown how to add different DataRecordPresenter Styles:
http://community.infragistics.com/forums/p/56753/290614.aspx
Please let me know if this helps you or you need further assistance on this matter.
That appears to work. Thanks.
Thanks again.
