1150
How to prevent schdule control from disappearing when all calendars are hidden
in my application, I will allow showing and hiding all calendars used in the schedule control (merged display mode). However, when all calendars are hidden, the control only shows a blank area instead of a calendar. I understand the reason, but I need a way around that. The calendar control should still be fully visible, with no calendar selected, but when adding a new item to it (double click for example) it should create the appointment in the default calendar and make this calendar visible again.
I'm not sure how to achieve this goal currently. I could add an empty default calendar that cannot be disabled by the user, but then the control also creates new appointments in it, which I'd like to prevent or rather "redirect" to a different calendar. Is that possible?
Best  regards,
Florian
