445
Displaying image in column and enable click functionality to open file.
I'm trying to display an image for a row when that row has a file (in this case a PDF) attached to it.  I have a True/False column called 'FileExists' which indicates if the row has a document associated with it.
So based on this this those rows that have a True value in the FileExists column should display an image.  I want the ability then to allow the user to click the image to open the assigned PDF file.
I have had a few attempts at this now based on other posts but can quite get it to work properly.
Any help would be most appreciated.
Troy
