Hello, I'm a Japanese. Sorry, I can speak English a little.
How to set combobox to cell of XamDataGrid. I saw exsample and news, Used XML resources. but i didn't find how to bind XamComboEditor from ViewModel's collection.
Now, I'm using ObjectDataProviderto to refer to article, but Iwant to use ViewModel collection. how to use it?
ComboBoxItemsProvider and ObjectDataProviderhttp://forums.infragistics.com/forums/p/9408/36631.aspx
<Window.Resources> <!--XamComboEditor Style--> <ObjectDataProvider x:Key="dataProvider" ObjectType="{x:Type local:VehicleTypes}" MethodName="Create" /> <Style x:Key="XamComboEditorStyle1" TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="ItemsProvider"> <Setter.Value> <igEditors:ComboBoxItemsProvider ItemsSource="{Binding Source={StaticResource dataProvider}}" DisplayMemberPath="Summary" ValuePath="TypeId" /> </Setter.Value> </Setter> </Style></Window.Resources>
' ------------------------------------------' ViewModelOption Explicit OnOption Strict On
Imports System.Collections.ObjectModelImports Livet
Public Class VehicleSearchViewModel Inherits ViewModel
#Region "コンストラクタ"
Public Sub New() Me.Options = VehicleOptions.Create() Me.Types = VehicleTypes.Create() End Sub
#End Region
#Region "プロパティ"
#Region "Options変更通知プロパティ" Private _Options As IEnumerable(Of Object)
Public Property Options() As IEnumerable(Of Object) Get Return _Options End Get Set(ByVal value As IEnumerable(Of Object)) _Options = value RaisePropertyChanged("Options") End Set End Property#End Region
#Region "Types変更通知プロパティ" Private _Types As IEnumerable(Of Object)
Public Property Types() As IEnumerable(Of Object) <DebuggerStepThrough()> Get Return _Types End Get Set(ByVal value As IEnumerable(Of Object)) _Types = value RaisePropertyChanged("Types") End Set End Property#End Region
#Region "Vehicles変更通知プロパティ" Private _Vehicles As ObservableCollection(Of Vehicle)
Public Property Vehicles() As ObservableCollection(Of Vehicle) Get Return _Vehicles End Get Set(ByVal value As ObservableCollection(Of Vehicle)) _Vehicles = value RaisePropertyChanged("Vehicles")
Me.ClearCommand.RaiseCanExecuteChanged() Me.DetailCommand.RaiseCanExecuteChanged() End Set End Property#End Region
End Class
Thanks.
thank you for your answer, but I'd like to ask you if it is also possible to do this with a ComboBoxItemsProvider instead of the ItemsSource property.
Maybe I should write a new post explaining the situation.
Chema
Thanks again.
Thanks for your reply.
Empty the list of XamComboEditor cause was because I did was remove the "ElementName = grid1" from your code. It was necessary this is. The problem is resolved.
If you have more than one XamComboEditor you can set the x:Key of the Style and set the EditorStyle Property of the Field's FieldSettings to that Style.
Thank you for your sample.
However, because of other XamComboEditor used in the Grid, this approach does not work.
I tryed to move xamDataGrid's resources. List of the XamComboEditor has been displayed in empty. If you think, this is sure?
Thank you.
