Hi!
I've a global styles.xaml file where I define the overall styles for my project. Now I want to define a special style for those columns in my XamDataGrid that have the attribute 'AllowEdit=False'.
<igDP:Field.Settings> <igDP:FieldSettings AllowEdit="False" /></igDP:Field.Settings>
I've already tried following, but that didn't work:
<Trigger Property="igDP:FieldSettings.AllowEdit" Value="False"> <Setter Property="igDP:DataRecordCellArea.Background" Value="Red"/></Trigger>
Any ideas?
Stephan
You can set the XamDataGrid’s FieldSettings AllowEdit Property to False. This way all the Fields will become read-only.
Hi... i am using 25 columns in my xamdatagrid.For each column i should call AllowEdit = "Flase".Can i call global style in <Grid.Resources> ?
Hello Stephan,
Thanks again.
Works perfect! Thanks!
Thank you for your post. I have been looking into it and I suggest you use the following Style for the CellValuePresenter:
<Style TargetType="{x:Type igDP:CellValuePresenter}"> <Style.Triggers> <DataTrigger Binding="{Binding RelativeSource={RelativeSource Self}, Path=Field.Settings.AllowEdit}" Value="False"> <Setter Property="Background" Value="Red"/> </DataTrigger> </Style.Triggers> </Style>
If you have already defined one, you just add the DataTrigger in it. Please let me know if this helps you or you need further assistance on this matter.
