60
Combobox in XamDataGrid Shows Empty
OK, this has been driving me crazy all morning.  I have a XAMDataGrid and I am trying to put a combo box inside one of the cells.  It shows up ok, but the combo box remains empty no matter what I try.  I had this working in regular datagrid, but switching to the XAMDataGrid I cannot make it work.  Here's the code
<igDP:XamDataGrid AutoFit="True" DataSource="{Binding}">
                <igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:FieldLayoutSettings AutoGenerateFields="False" />
                </igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:XamDataGrid.FieldLayouts>
                    <igDP:FieldLayout>
                        <igDP:FieldLayout.Fields>
                            <igDP:Field Name="Checked" Label="Output"/>
                            <igDP:Field Name="ColumnAlias" Label="Column"/>
                            <igDP:Field Name="selectedOperator" Label="Operator">
                            <igDP:Field.Settings>
                                <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}">
                                    <igDP:FieldSettings.EditorStyle>
                                        <Style TargetType="{x:Type igEditors:XamComboEditor}">
                                            <Setter Property="ItemsSource" Value="{Binding Operator}"/>
                                            <Setter Property="SelectedItem" Value="{Binding selectedOperator}" />
                                        </Style>
                                    </igDP:FieldSettings.EditorStyle>
                                </igDP:FieldSettings>
                            </igDP:Field.Settings>
                        </igDP:Field>
                        <igDP:Field Name="Criteria" Label="Criteria"/>
                        </igDP:FieldLayout.Fields>
                    </igDP:FieldLayout>
                </igDP:XamDataGrid.FieldLayouts>
            </igDP:XamDataGrid>
Operator is an observablecollection<string> property defined as..
        private ObservableCollection<string> _operator = new ObservableCollection<string>()
            {"=","<>",">",">=","<","<=","IN","IS NULL","IS NOT NULL"};
        public ObservableCollection<string> Operator { get { return _operator; } }
Everything else binds correctly, but the combo box shows empty.  Any ideas?
