I have a XamComboEditor in my XamDataGrid that I've successfully put different options into, and you can change options via the dropdown box, etc etc etc bottom line is that it works.
Unfortunately there is one problem that is really annoying, and I have not been able to find an answer scouring these forums. I have a default value that shows up, "Auto". You can change from this option, and the change stays. Switching back, "auto" then stays.
HOWEVER, from the initial default value "Auto", if you select the combo box as if to change it, but don't select anything... you can then click twice outside the box (one to cancel selection and then again to do something else such as select a record in the grid), "Auto" disappears!!!
In my code, I do not change the value of the currently selected item if the selection is "null", which is what happens in this situation. I'm calling the appropriate RaisePropertyChanged() method, yet the visual combobox still changes :(
Is there any way to stop this from happening? Even repeated calls to RaisePropertyChanged() do not fix this. And as I said, this is only on the very first initial value. Once you've changed the selection everything works as expected. Any thoughts?
That looks like the winner! Thank you!
Hello Ryan,
I can suggest you set the UnbondField's BindingMode to TwoWay and remove the setter for the SelectedItems. This way everything will work as you want. Please let me know if this helps you or you need further assistance on this matter.
Hey Stefan,
I'm really sorry... I didn't spend enough time looking at this yesterday. Today though, I found that while this fixes the blank boxes (even while scrolling), this starts to set the value of every combo box to the first value of the options list!
Attached is a modified example. Run it and change the first couple options to "two" or "three" instead of one. Now, scroll down, and then scroll back up. The options have been reset to "one"!
When I debugged into it, there was nothing in the call stack, so I have no idea what could be causing this...
Thanks for keeping up with this problem,
-Ryan-
Thanks again.
Yes! That did it. Thank you Stefan, you are awesome!
If anyone else stumbles upon this, the answer is to set the unbound field's "BindingPath" property
<igDP:UnboundField Label="Type" Row="0" Column="2" Width="80" BindingPath="Type"> <igDP:Field.Settings> <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="ItemsSource" Value="{Binding DataItem.TypeList}"/> <Setter Property="SelectedItem" Value="{Binding DataItem.Type, Mode=TwoWay}"/> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:UnboundField>
