1240
Unexplainable Binding Errors against FieldLayout.AutoFitToWidth
We're using XamDataGrid v11.2 and we get one BindingExpression path error for each XamDataGrid as it renders. The whole message is:
BindingExpression path error: 'FieldLayout' property not found on 'object' ''GridUserControl' (Name='')'. BindingExpression:Path=FieldLayout.AutoFitToWidth; DataItem='GridUserControl' (Name=''); target element is 'DataRecordPresenter' (Name=''); target property is 'NoTarget' (type 'Object')
The data context for the whole user control is pointing to our GridUserControl object and the XamDataGrid inherits that data context (we set the DataSource for the grid). The binding expression (FieldLayout.AutoFitToWidth) must be something internal to the XamDataGrid. I have searched our code completely (not case sensitive, not whole word, entire soluton, *.*) and there are no occurances of AutoFitToWidth (and any occurances of FieldLayout are not used in binding expressions).
Am I right that this is an internal issue with XamDataGrid v11.2? Is there anything I can do to get rid of this error (we log all binding errors and customers may be confused if they see this in our log)?
Mike
