Hi there,
I cannot set any Styles on the Navigator.
I tried it with an CalendarResourceProvider and it worked but the weeknumber and weekday fields are always with foreground black. I cannot set another color.
I tried also to create an style for the CalendarWeekNumber and CalendarDayOfWeek Classes but that has no effect.
Also I wanted to change the style of highlighted days with activities. They are only bold and that is not enough.
I'm using currently Version 11.1
Thanks for any answer!
Thank you for your feedback. Please let me know if you have any further questions on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
update 20111.2173 solved the problem.
thank you.
If you do not want to upgrade to 2011-2, I suggest you to unstall the latest service release for 2011-1, where this problem is resolved. I have checked this sample with the 20111.2193 service release, and it is working as expected.
Olga G.
OK first of all thank you for your help.
I have created a new project with 2011-1 build. Same issue.
On my Laptop I have now 2011-2 and there the same sample works.
Seems to be a bug of 2011-1.
The thing with the styles I will try later.
I have version 2011-1
I dont wanted to upgrade this week because I need a working version until weekend.
I will try this in a new project
