i'm using InfragisticsWPF4.Controls.Charts.XamDataChart.v11.2.
Is it possible to hide grid line in the chart?
Thanks!
Hi, i have added unknown series through series binding, but i can not be able to control multiple labels.How can i avoid that ??
Hi, Thanks for your input. But I managed a simpler way to finish my requirement. I set the strip property of the axis to some color. (which restricted the increase and decrease in grid lines as I zoomin and zoom out) and I just used the CategoryXAxis instead of CategoryDateTimeAxis. Its pretty straight forward to use categoryXAxis to display decimal values for the labels.
Thank you for your posts. I have been looking into your questions and since you are using CategoryDateTimeXAxis, I can suggest using a DataTempalte for the Label property of the axis and using a Converter to convert the DateTime value of the labels to the Ticks that corresponds to the DateTime. Regarding the fixed numbers of the grid lines on the x axis, as I have already mentioned, you can set the Interval property of the x axis and this way you will have fixed number of lines and labels. Also the amount of the labels will not change when you zoom, when using this approach. I have created a sample application for you, that demonstrates how you can show the ticks of the DateTime of the X axis and set the Interval property.
Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Also, I have started to use category datetime axis on your advice. I need to display labels on the x-axis as decimal numbers which is in time in nano seconds. My plot is a waveform which has time (nanoseconds) as xaxis and voltage on y axis.
I tried my best and I don't seem to have a work around with plotting just numbers as labels on the x-axis. Currently, I can only have a label for x-axis with category datetime axis if a fixed date and time format.
Thanks for the hint. Is there a way to stop the grid lines being added depending on the zoom level. The position of the grid lines is very important. I do not want the grid lines accumulating as I zoom in just to show detail on the chart.
Please help me with this scenario. Thanks.
