I have created a style to rotate some of the columns and display them verically within XamDataGrid. This works fine but when i apply this style to columns, the columns are displayed vertically in the field chooser as well. I tried creating a seperate style for field chooser which i have given below but the column header is still getting displayed vertically in field chooser. Can you please let me know how to solve this problem?
----Vertical Header----
<Style x:Key="VerticalHeader" TargetType="{x:Type controls:LabelPresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="controls:LabelPresenter"> <Border BorderBrush="{StaticResource WarmGrey_74}" Background="{StaticResource WarmGrey_74}"> <TextBlock Foreground="{StaticResource NptBlue_DarkText}" FontWeight="Bold" VerticalAlignment="Center" HorizontalAlignment="Left" TextAlignment="Center"> <ContentPresenter> <ContentPresenter.LayoutTransform> <RotateTransform Angle="-90" /> </ContentPresenter.LayoutTransform> </ContentPresenter> </TextBlock> </Border> </ControlTemplate> </Setter.Value> </Setter> </Style>
----Field chooser----
<Style x:Key="{x:Type controls:FieldChooser}" TargetType="{x:Type controls:FieldChooser}"> <Style.Resources> <!--FieldChooserEntry represents a field in the field chooser. This data template shows the checkbox inside the label presenter instead of the default which is show it left of the label presenter.--> <DataTemplate DataType="{x:Type controls:FieldChooserEntry}"> <Grid> <controls:LabelPresenter x:Name="label" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Field="{Binding Path=Field}" IsInFieldChooser="true" IsSelectedInFieldChooser="{Binding Path=IsSelected}" Padding="30,7,2,7"> <controls:LabelPresenter.Style> <Style TargetType="{x:Type controls:LabelPresenter}"> <Setter Property="Background" Value="{StaticResource WarmGrey_74}" /> <Setter Property="Foreground" Value="{StaticResource NptBlue_DarkText}" /> <Setter Property="FontWeight" Value="Bold" /> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type controls:LabelPresenter}"> <Grid> <Rectangle Fill="{TemplateBinding Background}" Stroke="{TemplateBinding BorderBrush}" StrokeThickness="1" SnapsToDevicePixels="True" /> <Rectangle x:Name="Highlight" Height="1" Margin="1" VerticalAlignment="Top" Stroke="#838383" SnapsToDevicePixels="True" StrokeThickness="1"/> <ContentPresenter TextElement.Foreground="{TemplateBinding Foreground}" Margin="{TemplateBinding Padding}" > </ContentPresenter> </Grid> <ControlTemplate.Triggers> <Trigger Property="IsMouseOver" Value="True"> <Setter Property="Cursor" Value="Hand"/> <Setter Property="Background" Value="{StaticResource WarmGrey_74}"> </Setter> </Trigger> <Trigger Property="IsSelectedInFieldChooser" Value="True"> <Setter Property="Background" Value="{StaticResource WarmGrey_74}"> </Setter> <Setter TargetName="Highlight" Property="Stroke" Value="{StaticResource NptBlue_LightText}"/> </Trigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> </Style> </controls:LabelPresenter.Style> <!--This is for toggling the visibility of a field by double clicking on it in the field chooser.--> <controls:LabelPresenter.InputBindings> <MouseBinding Command="{x:Static controls:FieldChooserCommands.ToggleVisibility}" MouseAction="LeftDoubleClick"/> </controls:LabelPresenter.InputBindings> </controls:LabelPresenter> <editors:XamCheckEditor x:Name="checkBox" HorizontalAlignment="Left" VerticalAlignment="Center" Margin="10,0,0,0" IsThreeState="false" Value="{Binding Path=IsVisible, Mode=TwoWay}"/> </Grid> <DataTemplate.Triggers> <!-- This trigger changes the appearance of labels in the field chooser that are currently hidden in the data presenter. --> <DataTrigger Binding="{Binding Path=IsVisible}" Value="False"> <Setter TargetName="label" Property="Background" Value="{StaticResource WarmGrey_74}"> </Setter> <Setter TargetName="label" Property="Foreground" Value="{StaticResource NptBlue_DarkText}"/> </DataTrigger> </DataTemplate.Triggers> </DataTemplate> </Style.Resources> <Style.Triggers> <!-- You can show some kind of visual queue when the user drags a field from the field chooser by using IsDraggingItem property.--> <Trigger Property="IsDraggingItem" Value="true"> <Setter Property="BorderThickness" Value="2"/> <Setter Property="BorderBrush" Value="Blue"/> </Trigger> <!-- You can show some kind of visual queue when the user drags a field from the data presenter using the IsDraggingItemFromDataPresenter property.--> <Trigger Property="IsDraggingItemFromDataPresenter" Value="true"> <Setter Property="BorderThickness" Value="2"/> <Setter Property="BorderBrush" Value="Gray"/> </Trigger> <!-- You can show some kind of visual queue when the user drags a field from the data presenter and moves it over the field chooser by using the IsDragItemOver property.--> <Trigger Property="IsDragItemOver" Value="true"> <Setter Property="BorderThickness" Value="2"/> <Setter Property="BorderBrush" Value="Green"/> </Trigger> </Style.Triggers> </Style>
From what I understood I was able to fix the issue by modifying the VerticalHeader style as shown below. Please let me know if this is right way to fix the issue.
<Style x:Key="VerticalHeader" TargetType="{x:Type controls:LabelPresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="controls:LabelPresenter"> <Border BorderBrush="{StaticResource WarmGrey_74}" Background="{StaticResource WarmGrey_74}"> <TextBlock Foreground="{StaticResource NptBlue_DarkText}" FontWeight="Bold" VerticalAlignment="Center" HorizontalAlignment="Left" TextAlignment="Center"> <ContentPresenter> <ContentPresenter.LayoutTransform> <RotateTransform Angle="-90" /> </ContentPresenter.LayoutTransform> </ContentPresenter> </TextBlock> </Border> </ControlTemplate> </Setter.Value> </Setter> <Style.Triggers> <Trigger Property="IsInFieldChooser" Value="true"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="controls:LabelPresenter"> <Border BorderBrush="{StaticResource WarmGrey_74}" Background="{StaticResource WarmGrey_74}"> <TextBlock Foreground="{StaticResource NptBlue_DarkText}" FontWeight="Bold" VerticalAlignment="Center" HorizontalAlignment="Center" TextAlignment="Center"> <ContentPresenter> </ContentPresenter> </TextBlock> </Border> </ControlTemplate> </Setter.Value> </Setter> </Trigger> </Style.Triggers> </Style>
Hi senthilkumaranc,
I'm not sure why the field-chooser specific style is not working. Are you adding the style to the resources of the XamDataGrid?
Another possible solution is that if all you are concerned about is the fact that the header is oriented vertically in field chooser and you want it to be horizontal then you can use the "IsInFieldChooser" property trigger in the VerticalHeader template you created to set the LayoutTransform to 0 angle. IsInFieldChooser property of the LabelPresenters in the field-chooser is initialized to true.
Hope this helps,
Sandip
