950
Insert a DataPresenter in a panel
Bonjour ,
I am trying to build a windows all with code (C#). All Work well : my problem is to insrt a DataPresenter in the DocumentContentHost. HOW DO THAT ?
Thank You Anthride
My Code is Folowing
DocumentContentHost documentContentHost11 = new DocumentContentHost ();
this
.XamDockManager.BeginInit();
this.XamDockManager.Panes.Clear();
SplitPane splitPane1 = new SplitPane();
// UnsplitPane est le trait pour positionner la souris
splitPane1.SplitterOrientation =
Orientation.Horizontal;
splitPane1.MaxWidth = 300;
// c'estr la lge maxi du trait a partir de la gauche par defo
SplitPane splitPane2 = new SplitPane();
XamDockManager.SetInitialLocation(splitPane2, InitialPaneLocation.DockedRight);
// c'estr la lge maxi du trait a partir de laDroite (DockedRight )
//Add both SplitPanes to xamDockManager's Panes collection
this.XamDockManager.Panes.Add(splitPane1);
this.XamDockManager.Panes.Add(splitPane2);
//Creation des ContentPanes : c'est l'espace entre le spliterr et la marge
ContentPane contentPane1 = new ContentPane();
contentPane1.Header =
"Liste des Structures" ;
contentPane1.Width = 250;
XamDataPresenter MyPresenter = new XamDataPresenter ();
MyPresenter.FieldLayoutSettings =
new FieldLayoutSettings();
//Add the ContentPane to splitPane2's Panes collection
splitPane1.Panes.Add(contentPane1);
//Add both ContentPanes to the TabGroupPane's Items collection
this.XamDockManager.Content = documentContentHost11;
SplitPane splitPane11 = new SplitPane();
###### MY PROBLEM IS HERE ####################
XamDataPresenter xamDataPresenter1;
xamDataPresenter1 =
new XamDataPresenter();
// You can data bind your instance of xamDataPresenter // instead of using the built in sample data
xamDataPresenter1.BindToSampleData =
true;
// this.layoutRoot.Children.Add(xamDataPresenter1);
splitPane11..LayoutTransform.Add(xamDataPresenter1);
// ?????????????? how insert a XamDataPresenter in the splitpane11
documentContentHost11.Panes.Add(splitPane11);
TabGroupPane tabGroupPane11 = new TabGroupPane();
splitPane11.Panes.Add(tabGroupPane11);
ContentPane contentPane11 = new ContentPane();
contentPane11.Header =
"Document11.xaml";
ContentPane contentPane12 = new ContentPane();
contentPane12.Header =
"Document12.xaml";
tabGroupPane11.Items.Add(contentPane11);
tabGroupPane11.Items.Add(contentPane12);
////Creation d'un ContentPanes : c'est l'espace entre le spliterr et la marge Droite dans ce cas
ContentPane contentPane4 = new ContentPane();
contentPane4.Header =
contentPane4.Width = 250;
////Add the ContentPane to splitPane2's Panes collection
splitPane2.Panes.Add(contentPane4);
this.XamDockManager.EndInit();
  • 3520
    Hi caiseodev,
    I'm having the following code which seems to work fine:
    XamDockManager dockManager = new XamDockManager();
    DocumentContentHost dch = new DocumentContentHost();
    SplitPane sp = new SplitPane();
    TabGroupPane tgp = new TabGroupPane();
    ContentPane cp = new ContentPane();
    XamDataPresenter xdp = new XamDataPresenter();
    xdp.BindToSampleData = true;
    cp.Content = xdp;
    tgp.Items.Add(cp);
    sp.Panes.Add(tgp);
    dch.Panes.Add(sp);
    dockManager.Content = dch;
    this.LayoutRoot.Children.Clear();
    this.LayoutRoot.Children.Add(dockManager);
    where "LayoutRoot" is the main grid in the window.
    Please, ammend the code above so it best suits your scenario, and you should not have problems.
    Hope this helps.
