I have a column that uses an IValueConverter to change the text. I'm using a style to insert a TextBlock to display this updated text in the cell. In my first attempt, I made a very simple style, just containing the TextBlock. As I've discovered, at a minimum, a ContentPresenter named PART_EditorSite needs to be in the style to get editting to work. I've attempted to copy the entire style over from the built-in styles to get the editor to display. The result is below; both the editor and textblock display at the same time while in view mode. While in edit-mode, the textblock does remain visible, but it is almost completely covered by the editor.
I copied the style from DataPresenterGeneric_Express.xaml
Here is the style:
<Style x:Key="StrikeStyle" TargetType="{x:Type igDP:CellValuePresenter}" BasedOn="{StaticResource {x:Type igDP:CellValuePresenter}}"> <Setter Property="VerticalAlignment" Value="Stretch" /> <Setter Property="VerticalContentAlignment" Value="Stretch" /> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}"> <igWindows:CardPanel> <Border x:Name="MainBorder" CornerRadius="{TemplateBinding CornerRadius}" BorderThickness="{TemplateBinding BorderThickness}" BorderBrush="{TemplateBinding BorderBrush}" Background="{TemplateBinding Background}"/> <TextBlock x:Name="Active" Text="{Binding Content, RelativeSource={RelativeSource TemplatedParent}, Converter={StaticResource StrikeConverter}}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Width="Auto" Height="Auto" SnapsToDevicePixels="True" Opacity="1"/> <ContentPresenter x:Name="PART_EditorSite" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" VerticalAlignment="{TemplateBinding VerticalContentAlignment}" Margin="{TemplateBinding Padding}" Style="{TemplateBinding ForegroundStyle}" /> </igWindows:CardPanel> <ControlTemplate.Triggers> <!-- HighlightAsPrimary --> <Trigger Property="HighlightAsPrimary" Value="true"> <Setter Property="Background" Value="{Binding Path=BackgroundPrimary, RelativeSource={RelativeSource Self}}"/> <Setter Property="BorderBrush" Value="{Binding Path=BorderPrimaryBrush, RelativeSource={RelativeSource Self}}"/> <Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundPrimaryStyle, RelativeSource={RelativeSource TemplatedParent}}"/> </Trigger> <!-- IsFieldSelected --> <Trigger Property="IsFieldSelected" Value="true"> <Setter Property="Background" Value="{Binding Path=BackgroundFieldSelected, RelativeSource={RelativeSource Self}}"/> <Setter Property="BorderBrush" Value="{Binding Path=BorderFieldSelectedBrush, RelativeSource={RelativeSource Self}}"/> <Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundFieldSelectedStyle, RelativeSource={RelativeSource TemplatedParent}}"/> </Trigger> <!-- IsSelected --> <Trigger Property="IsSelected" Value="true"> <Setter Property="Background" Value="{Binding Path=BackgroundSelected, RelativeSource={RelativeSource Self}}"/> <Setter Property="BorderBrush" Value="{Binding Path=BorderSelectedBrush, RelativeSource={RelativeSource Self}}"/> <Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundSelectedStyle, RelativeSource={RelativeSource TemplatedParent}}"/> <!--<Setter Property="Visibility" Value="Visible" TargetName="LeftBorder" />--> </Trigger> <!-- IsActive --> <Trigger Property="IsActive" Value="true"> <Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundActiveStyle, RelativeSource={RelativeSource TemplatedParent}}"/> <Setter Property="Visibility" TargetName="Active" Value="Visible"/> </Trigger> <!-- IsMouseOver --> <MultiTrigger> <MultiTrigger.Conditions> <Condition Property="IsMouseOver" Value="True"/> <Condition Property="IsSelected" Value="False"/> <Condition Property="IsFieldSelected" Value="False"/> </MultiTrigger.Conditions> <Setter Property="Background" Value="{Binding Path=BackgroundHover, RelativeSource={RelativeSource Self}}"/> <Setter Property="BorderBrush" Value="{Binding Path=BorderHoverBrush, RelativeSource={RelativeSource Self}}"/> <Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundHoverStyle, RelativeSource={RelativeSource TemplatedParent}}"/> </MultiTrigger> <!-- Field.IsFixedStateChanging JM 01-22-09 NA 9.1 FixedFields --> <DataTrigger Binding="{Binding Path=Field.IsFixedStateChanging, RelativeSource={RelativeSource Self}}" Value="True"> <Setter Property="Background" Value="#AA8DBAEB"/> <Setter Property="BorderBrush" Value="#AA8DBAEB"/> </DataTrigger> <!--SSP 5/27/09 NAS9.2 IDataErrorInfo Support--> <Trigger Property="IsDataErrorTemplateActive" Value="true"> <Setter TargetName="PART_EditorSite" Property="ContentTemplate" Value="{DynamicResource {x:Static igDP:DataPresenterBase.DataErrorContentTemplateKey}}" /> </Trigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> <Style.Triggers> <!-- DRCA Foreground Hover Trigger--> <!-- JJD 4/30/09 - TFS17157 use new IsRecordSelected property --> <Trigger Property="IsRecordSelected" Value="True"> <Setter Property="ForegroundStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" /> </Trigger> <!-- DRCA Foreground Selected Trigger--> <!-- JJD 4/30/09 - TFS17157 use new IsMouseOverRecord property --> <Trigger Property="IsMouseOverRecord" Value="True"> <Setter Property="ForegroundStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" /> </Trigger> </Style.Triggers> </Style>
The only change I made was replacing the Rectangle with the TextBlock.
Original:
<Rectangle x:Name="Active" Fill="{TemplateBinding BackgroundActive}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Width="Auto" Height="Auto" SnapsToDevicePixels="True" Opacity="1" Visibility="Collapsed" StrokeThickness="1" Stroke="{TemplateBinding BorderActiveBrush}"/>
Changed to:
<TextBlock x:Name="Active" Text="{Binding Content, RelativeSource={RelativeSource TemplatedParent}, Converter={StaticResource StrikeConverter}}" HorizontalAlignment="Stretch" VerticalAlignment="Stretch"Width="Auto" Height="Auto" SnapsToDevicePixels="True" Opacity="1"/>
Hello David,
Thank you for your feedback. I am glad that I helped you to resolve your issue and I believe that other community members may benefit from this as well.
Thanks again.
Thanks Stefan,
I have updated the XamNumericEditor style to use the converter there. Works like a charm.
<Style x:Key="StrikeStyle" TargetType="{x:Type igEditors:XamNumericEditor}" BasedOn="{StaticResource {x:Type igEditors:XamNumericEditor}}" > <Setter Property="ValueToDisplayTextConverter" Value="{StaticResource StrikeConverter}"></Setter> <Setter Property="ValueToTextConverter" Value="{StaticResource StrikeConverter}"></Setter> </Style>
Thank you for your post. I have been looking into it and I suggest you use the default Style for the XamNumericEditor, in your case, because the Content of the CellVAluePresenter is an Editor and all the XamEditors has Template and EditTemplate Properties, which defines the look of the Control, while in and outside EditMode. You can find the default Styles in the Editors folder and there in the EditorsGeneric.xaml and EditorsGenericExpress.xaml files. Please let me know if this helps you or you need further clarifications on this matter.
