1485
Double-click on nodes only?
I currently have a MouseDoubleClick "event handler" (actually using EventToCommand from Cinch, similar to what MVVM Light offers), but this triggers no matter where I double-click on the tree.  I would like to be able to restrict double-clicks to when the user clicks on an actual node.
I tried setting a style on XamDataTreeNodeControl, but that doesn't do anything.  My tree is defined using NodeLayouts which do not have a MouseDoubleClick event.  I was hoping that using PreviewMouseDoubleClick to filter using the sender would work, but the type of sender is XamDataTree even when I double-click on a node (the WPF treeview actually distinguishes between the two, and I was hoping for the same behavior).
Any idea?  I get the feeling I'm missing something really obvious...
Michel
Parents Reply Children
No Data
