185
Disable specific Nodes in xamOrgChart or hide them
How can I disable Nodes based on a Property in the data object.
I tried setting the IsEnabled Property in OrgChartNodeLayout, but that doesn't seem to work.
                <ig:OrgChartNodeLayout TargetTypeName="ArbeidsPaket"
                                       Key="TeilLeistungen"
                                       ToolTipPath="Tooltip" IsEnabled="{Binding VisibleInDiagram}" >
Best Regards
  • 335
    Verified Answer
    Have you tried to use the NodeControlAttachedEvent? This event is rised every time a NodeControl is created. You can check if the DataContext of the Node of the NodeControl satisfies some condition and if it does, you can set the IsEnablet property to true/false for the specific NodeControl.
    Example in XAML:
    <ig:XamOrgChart x:Name="myOrgChart" NodeControlAttachedEvent="myOrgChart_NodeControlAttachedEvent" />
    In code:
    private void myOrgChart_NodeControlAttachedEvent(object sender, Infragistics.Controls.Maps.OrgChartNodeEventArgs e)
    if (e.Node.DataContext.GetType() == typeof(Order))
    e.Node.IsEnabled = false;
    This will disable all nodes of type Order.
