1085
Problem with Bindings in DataGrid
I am having problems with the Bindings in XamDataGrid. I have an MVVM application where the Model uses a DynamicBindingProxy to bind the properties of the datacontract. This works fine with normal bindings. Using XamDataGrid i get no data at all. Also when i try to access the properties which are in the stores in DataInstance in the model i get no result. It seems to me as if when i use a "." in the Name Property of the Field Tag it does not work:
Does not Work:
<igDP:XamDataGrid.FieldLayouts>
 <igDP:FieldLayout>
   <igDP:Field Label="Login" Name="DataInstance.Login"/>
  </igDP:FieldLayout>
Works:
with an additional
 <igDP:FieldLayout>
   <igDP:Field Label="Login" Name="Login"/>
  </igDP:FieldLayout>
public string Login { get { return DataInstance.Login; } set { DataInstance.Login = value; } }
in the model
