20
Scrollbars in xamDataTree
Hi everyone,
I recently stumbled over some strange behavior of the xamDataTree:
The normal behavior of a treeview with a vertical scrollbar is that the height of the Scrollbars thumb is (1) either fix or (2) it displays the ratio of the currently visible data to the whole data contained.(e.g. if i have 200 lines in a listview and i can display 100 of them the thumb in the scrollbar would be half the height of the Listbox). Is there a simple solution to achieve the behavior described in (2) for the xamDataTree as the default behavior is quiet confusing: It is not fixed size but resizes in an inexplicable way ?
thank you
Christian
  • 1670
    Hi CSteiner,
    Thank you for sharing that information! I have managed to reproduce your problem here! In the past there were some bug fixes arround scrolling feature for xamDataTree, which might have caused that current behaviour. I will talk with Development to ask about their opinion here and will let you know about their decision! I hope to be able to answer you very soon!
    Nikola.
