I upgraded to V11.2 and since then all kinds of weird things are happening.
Presentation framework seems to be trying to load XamPivotGrid V11.1 when there are no references to this in the solution. See exception below
Why is that?
Sangeetha
Hello Sangeetha,
I am glad to hear have found something. I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
Hi Petar,
I did a search for V11.1 in my solution, and found that a Style.Xaml which is a copy of generic.aml from V11.1 was referencing PivotGridV11.1.
Hopefully it should work fine now.
Thank You for your reply. Yes I checked and double-checked. The projects are not referencing any of the old libraries in V11.1. I was wondering if PresentationFramework.dll needs to be updated for V11.2
Meanwhile i will prepare a short sample.
I have been looking into your issue and usually this exception is thrown when a project is referencing an assembly which is no longer available. Could you please double-check if you have forgotten such a reference. If that is not the case would you please attach your sample so we can look into it more thoroughly.
