We use the infragistics xamDataGrid (V11.1). My grid can have multiline rows which can reach a height of more then the screen height.
The problem is, that when i scroll with the mouse wheel, the grid always jump 3 rows, so that the user cant see the items in it. Also if i try to use the scrollbar, it is not possible to read the full content of a row, when it needs more space (height) than available.
Is there a way to switch to a "smooth" scroll? I see, that infragistics use this on horizontal scrolling - so that the user can also scroll a half column - or something like this.
Please vote for the existing Feature request regarding this issue on http://ideas.infragistics.com
Search for smooth in the WPF category.
I was wondering if there is a fix for this yet. It's very obnoxious that one "click" of the scroll wheel can pass up multiple records. Smooth web-like scrolling would be much preferred for our grid, which contains rows of different heights.
Hello Andreas,
I can say that you can remove the XamDataGrid’s Scroll, but you are not able to add a custom ScrollViewer to scroll through the Records. If I think of a possible way to do that, I will update you with the solution.
Hope this helps you.
Thank you.
Is there a workaround for this problem?
Maybe - is it possible to disable the scrolling inside the grid and use a external Scrollviewer?
Regards Andreas
After some research, Smooth scrolling the grid has been determined to be a new feature request. I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR13736.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
