I'm trying to add my own template to the thumb for a XamNumericSlider, and have used the pattern described in the xamSlider->Thumb Styling sample in the Feature Browser. However, there are some issues:
1. The Feature Browser sample uses a XamNumericRangeSlider, and if I replace this with a XamNumericSlider I get a compile error like "Cannot add content to object of type 'Infragistics.Controls.Editors.XamNumericSlider' ". To solve this error I have to make my own subclass of XamNumericSlider and set its ContentProperty value to "Thumb". Why is XamNumericRangeSlider and XamNumericSlider different in this case ?
2. When using my thumb template the slider's track fill starts at a value of half the thumb width and also extends beyond the slider's max value with the same amount. I get the same effect if I use the original XamNumericRangeSlider sample. How can I fix this ?
HI,
I am following up on this post.
Please let me know if you need further assistance.
Sincerely, Matt Developer Support Engineer
This issue should be resolved by the latest service release.
Thank you for your reply. My current workaround for item 2 is to disable the track fill, but I'm looking forward to a bug-fix since my slider looks far better with the track fill turned on.
Leif
Hello leifop,
Thank you for sharing your experience with xamSlider control. I will try to answer your questions :
1. The XamNumericSlider is different than XamNumericRangeSlider and you can not directly set the XamNumericSliderThumb , you should set it to Thumb property of XamNumericSlider, because simple sliders (XamDateTimeSlider including) do not support Content directly.
2. The second question actually seems to be a bug and after discussion with responsible developer i have created a work item in our bug tracking system for you. I will contact your DS to create a case for you so that you are notified when it is fixed.
If you have any other difficulties , please feel free to share them! Thank you in advance!
Nikola.
