160
AddRecord is overwritten
When adding a new record in the XamDataGrid I use the following to initialize the added record
private void NotesViewGrid_InitializeTemplateAddRecord(object sender, Infragistics.Windows.DataPresenter.Events.InitializeTemplateAddRecordEventArgs e)
             e.TemplateAddRecord.SetCellValue(e.TemplateAddRecord.FieldLayout.Fields[0], notesViewModel.GetDefaultNote().Priority);
             e.TemplateAddRecord.SetCellValue(e.TemplateAddRecord.FieldLayout.Fields[2], notesViewModel.GetDefaultNote().Reviewer);
             e.TemplateAddRecord.SetCellValue(e.TemplateAddRecord.FieldLayout.Fields[3], notesViewModel.GetDefaultNote().Updated);
When the record is displayed the values are correctly initialized and displayed. However as soon as the user edits a value in a cell of the added row all the other cells loose their default value.
This occurs after the NotesViewGrid_EditModeStarted event as soon as the user enters a value in the cell. A new DataItem gets created on cell edit wiping out all the initialized values. How does one prevent this from happening?
  • 17559
    Hello neojones,
    I was looking into the issue you are describing and I tested it with handling ItnitilizeTemplateAddRecord event and setting  values for the cells. However I am not able to reproduce the behavior you are describing. Could you please modify the attached sample in order to represent the issue, so I can continue investigating this.
    Thanks in advance.
    InitializeTemplateAddRecordIssue.zip
