I'm working on application that needs to be able to run on a high resolution monitor (2550x1440). One or our WPF controls uses the XamDockManager. When this control is displayed in size 2400x1200 or larger, a redocking action will cause the system to crash due to an out of memory exception.
To isolate the problem, I have created a test application with nothing but a XamDockManager sitting in a large MainWindow.xaml. I was able to reproduce the crash with the same exception signature.
The exception tracing is shown below. The test MainWindow.xaml is attached to this post. If anybody have ran into the same problem and found a fix for it, please share. Thank you.
Exception:
System.OutOfMemoryException: Insufficient memory to continue the execution of the program.
at System.Windows.Media.Composition.DUCE.Channel.SyncFlush() at System.Windows.Media.MediaContext.CompleteRender() at System.Windows.Interop.HwndTarget.OnResize() at System.Windows.Interop.HwndTarget.HandleMessage(WindowMessage msg, IntPtr wparam, IntPtr lparam) at System.Windows.Interop.HwndSource.HwndTargetFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow) at System.Windows.Window.ShowHelper(Object booleanBox) at System.Windows.Window.Show() at Infragistics.Windows.Controls.ToolWindowHostWindow.Show(Boolean activate) at Infragistics.Windows.Controls.ToolWindow.ShowInToolWindowHostWindow(Boolean activate, Window owningWindow) at Infragistics.Windows.Controls.ToolWindow.ShowImpl(FrameworkElement owner, Boolean activate) at Infragistics.Windows.Controls.ToolWindow.Show(FrameworkElement owner, Boolean activate, Boolean preferPopup) at Infragistics.Windows.DockManager.DockManagerUtilities.ShowToolWindow(ToolWindow window, FrameworkElement owner, Boolean activate) at Infragistics.Windows.DockManager.Dragging.DragManager.ShowDropPreview(FrameworkElement owner, DropPreviewTabLocation location, Size size, HorizontalAlignment horzAlign, VerticalAlignment vertAlign, Double offsetX, Double offsetY, PaneLocation targetLocation) at Infragistics.Windows.DockManager.Dragging.DragManager.ShowDropPreview(FrameworkElement owner, DropPreviewTabLocation location, Nullable`1 sideForNone, Size size, Double offsetX, Double offsetY, PaneLocation targetLocation) at Infragistics.Windows.DockManager.Dragging.DragManager.ShowDropPreview(FrameworkElement owner, Dock side, Size size, Double offset, PaneLocation targetLocation) at Infragistics.Windows.DockManager.Dragging.AddToGroupActionBase.PerformAction(DragManager dragManager, Boolean isPreview) at Infragistics.Windows.DockManager.Dragging.DragManager.ProcessDragMove(IInputDeviceInfo e, Nullable`1 windowRect) at Infragistics.Windows.DockManager.Dragging.DragManager.ProcessDragMove(MouseEventArgs e) at Infragistics.Windows.DockManager.Dragging.DragManager.OnDragElementMouseMove(Object sender, MouseEventArgs e) at System.Windows.Input.MouseEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.ContentElement.RaiseTrustedEvent(RoutedEventArgs args) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.Run() at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run()
Thank you for your update and it is good to know that everything is working. Regarding the issue that you saw, if the combo box took focus when you dropped it down, then it is likely that is was the same issue. We addressed the issue with the exception being thrown by the XamDockManager in a later service release though the fix only prevents the exception and the drag operation would end.
I was having the same problem. The problem ended up being a combo box inside the content pane that was opening and closing its drop down list in the combo box's loaded event. Whenever I would drag the pane that event would fire and cause the stack trace you mentioned. Handling the loaded event in the combo box was a working around for a different WPF bug. Andrew's post about the Menu causing the problem ended up pointing me in the right direction. We approached the Combo Box WPF bug in a different manner and everything works now.
NarayanNB said: after removing custom template from contentpane and paneHeaderPresenter control getting the below exception
We tried running a sample using the original post's xaml on a system where the monitor's resolution is 2560x1600 and didn't reproduce the original issue nor the exception you are mentioning. Actually your issue sounds like it is different - as if something is happening during the drag processing and the drag is getting cancelled. The only such issue that comes to mind was a scenario where a contentpane contained a Menu and it was in the tab order so when the ContentPane was activated during the drag and focus was shifted to the first control that was the Menu which took mouse capture ending the drag. If that's not your issue then please provide a sample project that demonstrates the exception you are mentioning and we can look into it further.
System.NullReferenceException occurred
Message=Object reference not set to an instance of an object.
Source=InfragisticsWPF4.DockManager.v11.1
StackTrace:
InnerException:
Still it happens after removing retemplated styles to contentpane and PaneHeaderPresenter controls
