Can we generate a bubble chart with bubbles colored in a pie chart fashion.
I can suggest you handle the XamPieChart’s PreviewMouseLeftButtonDown event and add the following code in its handler:
MessageBox.Show((((e.OriginalSource as Path).Parent as Slice).DataContext as BreakDownItem).Label.ToString());
Hope this helps you.
Hi
How can i get the Label of the Bubble(PieChart),when i clicked on it.
Sorry, this slipped through the cracks. There is no built in feature. You can customize the marker templates, or you can float controls over the chart. Customizing the marker templates is probably the easier solution.
-Graham
Hello Graham,
Is there any default feature in bubble series to display some text? Customizing the bubble is an option and the way you explained above, i can use Pie chart and give some label and displaying that text on bubble can also be done. The problem in the second approach is just to display text on bubble i have to use pie chart on bubble series so this can be performance hit. Can you please let me know some better approach to suit my requirement?
Thanks!
I am trying to achieve exactly what you have described here, a Bubble chart with piechart-like datapoints but all I have is the WPF Toolkit. Can this be done with the charting controls on the toolkit? if possible please help me with the code as i have already tried, to no avail.
