210
Printing a Chart in a Grid
I have several charts in a grid to support a complex reporting layout.  I can get everything else on the grid to print, but the charts do not show up.  Here is the code to print the grid.  I set the series and some markers in procedural code when the datacontext changes on the form, and this may be the problem, but I can't seem to find any information on printing...
Code:
PrintDialog printDialog = new PrintDialog();if (printDialog.ShowDialog() == true)
int pageMargin = 5;
// Get the size of the page.
Size pageSize = new Size(printDialog.PrintableAreaWidth, printDialog.PrintableAreaHeight);
// Trigger the sizing of the element.
gMain.Measure(pageSize);
gMain.Arrange(
new Rect(pageMargin, pageMargin,
pageSize.Width, pageSize.Height));
// Print the element.printDialog.PrintVisual(gMain, "A Scaled Drawing");
// Remove the transform.
gMain.LayoutTransform = null;
 In some cases, I get a Null Reference exception and I was able to narrow it down to the charts in the traces....
  • 28496
    i tested this code in the Window_Loaded event handler of a window with a Grid in it, containing a chart.  it showed up OK.
    could you provide whatever sample code i might need to reproduce this, or maybe some steps for me to follow?
    if you provide the stack trace for a null reference exception, i could also investigate what's going on there.
