Hi there!
I got a problem with creating mapElements (here Pathelements and Symbolelements tested).
I I add them programmaticly to a new layer, I can't see them on the map, but they are in the elements collection of the layer.
If I add them to a layer, where a shapefile is loaded in (as an example american powerplants as point shapes) then I can see the added Elements, but just if at least one element of the existing power plant points is in the current mapview. For example if i zoom or move to europe, the added mapelements disappear!
Does anyone has any suggestion for this?
I used the following code for adding layer:
Dim kkwLayer As New MapLayer() kkwLayer.LayerName = "kkwLayer" reader = New ShapeFileReader() reader.Uri = "/../../Shapefiles/nuclear-facilities-update" converter = New DataMapping.Converter() reader.DataMapping = TryCast(converter.ConvertFromString("ToolTip=NAME"), DataMapping) kkwLayer.Reader = reader kkwLayer.SymbolType = MapSymbolType.Pentagram theMap.Layers.Add(kkwLayer)
and the following code to add SymbolElements in the mapmouseleftup event:
Dim theMap As XamMap = DirectCast(sender, XamMap) Dim mousePosition As Point = e.Position Dim mapPosition As Point = theMap.Viewport.RootCanvas.RenderTransform.Inverse.Transform(mousePosition) Dim geoPosition As Point = theMap.MapProjection.UnprojectFromMap(mapPosition) Dim latitude As Double = geoPosition.Y Dim longitude As Double = geoPosition.X ' Get Point data using a projection from Geodetic to Cartesian coordinates Dim origin As Point = theMap.MapProjection.ProjectToMap(New Point(longitude, latitude)) 'Dim origin As Point = geoPosition Dim element As New SymbolElement() element.SymbolOrigin = origin element.Caption = "Marker" element.SymbolType = MapSymbolType.Pentagon element.SymbolSize = 15 theMap.Layers("kkwLayer").Elements.Add(element)
The same is happening with PathElements, did not try with SurfaceElements
Thanks a lot in advance!
Edit: I have OpenStreetmaps as Geoimaginery in the background
I found the solution myself. the isAutoWorldRect property has set to be true to the layer.
kind regards
Hi Creepin,
Try setting new layer's WorldRect. If it's empty layer's elemens will not be shown. Please try the following snippet:
Rect worldRect = theMap.Layers("kkwLayer").WorldRect;worldRect.Union(element.WorldRect);
theMap.Layers("kkwLayer").WorldRect = worldRect;
Ivan Kotev
