695
Multiline Text editor and custom column width
I have a field with varchar(MAX) and I want to do two things.
Multiline editor which accepts carriage return for a new line.
I am using the following style but I still can not make a new line. I tried Enter, Control+Enter, Alt+Enter.
    <Window.Resources>
        <Style TargetType="igEditors:XamTextEditor" x:Key="TextboxWrapping">
            <Setter Property="TextWrapping" Value="Wrap" />
            <Setter Property="Height" Value="75" />
            <Setter Property="VerticalScrollBarVisibility" Value="Auto" />
            <Style.Resources>
                <Style TargetType="{x:Type igEditors:XamTextEditor}">
                    <Setter Property="AcceptsReturn" Value="True"/>
                </Style>
            </Style.Resources>
        </Style>
    </Window.Resources>
Code
Style cvp  = (Style) Resources["TextboxWrapping"];
foreach (Field field in eventsGrid.FieldLayouts[0].Fields)
    if (field.Name == "Description"))
        field.Settings.EditorStyle = cvp;
Want to make custom column widht
I want to set this column width to custom-width, say 300. But I don't see any way to do this.
I only see the following two options and both are setting the column width 2x of my monitor.
field.Width = FieldLength.InitialAuto;
field.Width = FieldLength.Auto;
Thanks in Advance
Sreekanth
Parents
  • 27093
    Hello Sreekanth,
    If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Reply Children
No Data
