1935
MVVM and XamDataGrid
I'm new to Infragistics and I therefore have a question regarding MVVM and databinding in the XamDataGrid.
What I need to know is, how I have to write the XAML for the DataGrid in order to bind properties to the columns of the grid?
I have set the DataContext of my MainWindow to an instance of a class containing a ObservableCollection with the items that I want to display. I then set the DataSource of the XamDataGrid to "{Binding Calculations}". But this apparently isn't enough...
I would also like to know how to get an instance of the selected item?
Current XAML:
<igDP:XamDataGrid
            Grid.Row="1"
            x:Name="MyGrid"
            DataSource="{Binding Calculations}"
            AssigningFieldLayoutToItem="MyGrid_AssigningFieldLayoutToItem">
            <igDP:XamDataGrid.FieldSettings>
                <igDP:FieldSettings
                    CellClickAction="SelectRecord"
                    AllowEdit="True" />
            </igDP:XamDataGrid.FieldSettings>
            <igDP:XamDataGrid.FieldLayouts>
                <igDP:FieldLayout Key="master">
                    <igDP:Field Name="ShortName" />
                    <igDP:Field Name="Name" />
                    <igDP:Field Name="Min" />
                    <igDP:Field Name="Prob" />
                    <igDP:Field Name="Max" />
                    <igDP:Field Name="Mean" />
                </igDP:FieldLayout>
                <igDP:FieldLayout Key="nested">
                    <igDP:Field Name="ShortName">
                        <igDP:Field.Settings>
                            <igDP:FieldSettings LabelPresenterStyle="{StaticResource MyStyle}" />
                        </igDP:Field.Settings>
                    </igDP:Field>
                    <igDP:Field Name="Name">
                    </igDP:Field>
                    <igDP:Field Name="Min">
                    </igDP:Field>
                    <igDP:Field Name="Prob">
                    </igDP:Field>
                    <igDP:Field Name="Max">
                    </igDP:Field>
                    <igDP:Field Name="Mean">
                    </igDP:Field>
                </igDP:FieldLayout>
            </igDP:XamDataGrid.FieldLayouts>
        </igDP:XamDataGrid>
