I'm having trouble with the component XamOrgChart. The documentation only shows examples with XML file. How to use SQL server with IDParent?? I suggest to include documentation such example. thanks
You can set up the Global Node Layouts to use the Definition the Database tables and the associated relationships.
For example, if I create an Entity Data Model for the Employee in the NorthWind database such that my Entity is Employee and my Relationship is named Employees1.
Then I can create my Global Node Layouts to use this relationship:
<ig:XamOrgChart x:Name="NWOrgChart" Margin="100,100">
<ig:XamOrgChart.GlobalNodeLayouts>
<ig:OrgChartNodeLayout TargetTypeName="Employee"
DisplayMemberPath="LastName"
<ig:OrgChartNodeLayout TargetTypeName="Employees1"
Key="Employees1"/>
</ig:XamOrgChart.GlobalNodeLayouts>
</ig:XamOrgChart>
Then I only need to massage my data back from the database slightly to ensure I only have one root:
Employees = context.Employees;
var Managers = (from emp in Employees
where emp.Employee1 == null
select emp).ToList();
NWOrgChart.ItemsSource = Managers;
and I have my Org Chart.
I have attached a sample which uses SL but the code should be relatively the same using WPF.
Sincerely,
Valerie
Developer Support Engineer
www.infragistics.com/support
I'm having the same issue....
Any response???
Fabian.
