I have an Excel 2007 workbook with some charts defined. I Load() the workbook, make a few changes, and then save it to the same file. When I open the workbook, the charts are not preserved.
In fact, if I just Load()/Save(), the charts are gone. Is this a known issue? Is there a workaround?
Hello Kobieb,
The service release containing the fix for your issue is out, you can download it from: https://es.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
I have created a support case number CAS-68883-M68L4P for you about this behavior and I have linked it with Development issue 82969 on our internal tracking system.
I will leave this case open and update you with any new information after the review. You can also continue to send updates to this case at any time.
You can view the status of the development issue connected to this case by going to the “My IG” tab on our website, hovering to the "My Support Activity" dropdown and selecting the "Development Issues" tab.
Please let me know if you need more information.
Hello kobieb,
After further reviewing this issue and testing it with pictures with different sizes I succeed in reproducing the mentioned behavior so I am going to ask our developers to investigate this further.
I will update you on my progress in a business day.
I reviewed your questions and test it with.xlsx file with chart. I tried to load the workbook and save it and I am not able to reproduce the issue you are describing. Could you please provide me with more information about the version of Microsoft Excel you use and a small sample where the behavior is reproducible.
Thanks in advance.
It could be a bug. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
