Dear Support,
I'm trying to bind the OutlookBar-Groups-Collection to a Collection view. The Groups are shown, but selection of a group does not fire the "CurrentChanged"-Event of the CollectionView.Furthermore .MoveCurrentToLast does not select the last Item in your OutlookBar. It does not work in any direction. In order to be sure that everythin is correct, I additionally bound a ListBox to the SAME Collection and everything works fine here. I assume that your OutlookBar does not work with MVVM.
Please check the following XAML and give us a hint how to combine your Product and a CollectionView: OutlookEntries is the collectionView
<igOutlookBar:XamOutlookBar DataContext="{Binding OutlookEntries, Mode=TwoWay}" GroupsSource="{Binding}" DockPanel.Dock="Left" HorizontalAlignment="Left" Name="OutBar" Width="200" IsTabStop="False" MaxWidth="600" MinWidth="100" Theme="Generic"> <igOutlookBar:XamOutlookBar.Resources> <Style TargetType="{x:Type igOutlookBar:OutlookBarGroup}"> <Setter Property="Header" Value="{Binding Header}"/> <Setter Property="SmallImage" Value="{Binding SmallImage}"/> <Setter Property="LargeImage" Value="{Binding LargeImage}"/> </Style> </igOutlookBar:XamOutlookBar.Resources> </igOutlookBar:XamOutlookBar>
I have logged this feature request on your behalf. I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR13367.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Thank you very much for your sample.
Didn't expected that much code for this issue. But thank you for the workaround. I will write a "feature request", nethertheless.
By the way, while studiing several threads here I found out that there are severel questions regarding MVVM with your controls. And it seems that there is a demand for a couple of such "feature requests".
Are there any plans from Infragistics for something like a complete re-check/overhaul of the WPF-Suite in order to support MVVM without workarounds? Would make our live much easier and save a lot of time at our end. As per my point of view, most of all WPF-Users do or should work with MVVM instead of CodeBehind. Of course, there are some exceptional cases but 3rd-Party-Controls should be such a case in my point of view.
voks said:I'm trying to bind the OutlookBar-Groups-Collection to a Collection view. The Groups are shown, but selection of a group does not fire the "CurrentChanged"-Event of the CollectionView.Furthermore .MoveCurrentToLast does not select the last Item in your OutlookBar. It does not work in any direction. In order to be sure that everythin is correct, I additionally bound a ListBox to the SAME Collection and everything works fine here. I assume that your OutlookBar does not work with MVVM.
Essentially what you are looking for is IsSynchronizedWithCurrentItem support in XamOutlookBar like the WPF Selector class (from which ListBox derives) has. I don't agree with saying that not having it means the control does not support MVVM. I would recommend submitting a suggestion for building support for this into the control. For now it is feasible to write your own attached behavior that does this. I have attached an example of doing so.
Just tried the Telerik-Control and this does work very well, also.
So, any hint reply would be highly appreciated!
