Since I have installed the hotfix, I got the following errors during compilation :
Error 29 The type reference cannot find a public type named 'CellValuePresenter'. Error 30 The type reference cannot find a public type named 'XamTextEditor'.Error 31 The type reference cannot find a public type named 'CellValuePresenter'.Error 32 The type reference cannot find a public type named 'CarouselItem'.Error 33 The type reference cannot find a public type named 'CarouselItem'. Error 34 The type reference cannot find a public type named 'CarouselPanelNavigator'.Error 35 The tag 'CarouselView' does not exist in XML namespace 'http://infragistics.com/DataPresenter'.Error 36 The tag 'CarouselView' does not exist in XML namespace 'http://infragistics.com/DataPresenter'.Error 37 The tag 'XamDataPresenter' does not exist in XML namespace 'http://infragistics.com/DataPresenter'Error 38 The tag 'XamDataPresenter' does not exist in XML namespace 'http://infragistics.com/DataPresenter'.Error 39 The type reference cannot find a public type named 'DataRecordPresenter'.Error 40 The tag 'GridView' does not exist in XML namespace 'http://infragistics.com/DataPresenter'.Error 41 The type reference cannot find a public type named 'CellValuePresenter'.Error 42 The tag 'XamDataPresenter' does not exist in XML namespace 'http://infragistics.com/DataPresenter'.
Hi -
It sounds like references to the DataPresenter assembly are not being resolved properly. Check your project references (you may want to remove them and re-add them to be sure).
Joe
You're right, thanks...
But I m still waiting since a lot of time now for a solution to the post : http://forums.infragistics.com/forums/t/4035.aspx
Please, can you help or even tell me if there exist a solution ?
