Hi
is it possible to give the xamDataTree / xamDataGrid rounded corder of the border ?
Your solution does not work. I need all the Text Editors (TextBox etc) as round corner control. How to do that. This is a lethargic solution. There should be some properties for each control to have cornerradious.
Fayaz
Were you able to style the controls?
Valerie
You can find the styles for the controls under the Directory Program Files\Infragistics\NetAdvantage 2011.1\WPF\DefaultStyles. You can then modify the styles to round the corners by adding CornerRadius to the Borders:
<Style TargetType="igDT:XamDataTree">
<Setter Property="Background" Value="White"/>
<Setter Property="BorderBrush" Value="{StaticResource SilverlightDarkBrush}"/>
<Setter Property="BorderThickness" Value="1"/>
<Setter Property="Foreground" Value="Black"/>
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="igDT:XamDataTree">
<Border x:Name="Bd" Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}" CornerRadius="15,15,15,15">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="*"/>
<RowDefinition Height="Auto"/>
</Grid.RowDefinitions>
<Grid.ColumnDefinitions>
<ColumnDefinition Width="*"/>
<ColumnDefinition Width="Auto"/>
</Grid.ColumnDefinitions>
<igPrimDT:NodesPanel x:Name="NodesPanel" />
<ScrollBar x:Name="VerticalScrollBar" Width="20" Grid.Row="0" Grid.Column="1"/>
<ScrollBar x:Name="HorizontalScrollBar" Height="20" Grid.Row="2"/>
</Grid>
</Border>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
<Style TargetType="{x:Type igDP:XamDataGrid}">
<Setter Property="Background" Value="{DynamicResource {x:Static igDP:DataPresenterBrushKeys.BaseBackgroundKey}}"/>
<ControlTemplate TargetType="{x:Type igDP:XamDataGrid}">
<Border Background="{TemplateBinding Background}" BorderBrush="{TemplateBinding BorderBrush}" BorderThickness="{TemplateBinding BorderThickness}" CornerRadius="15,15,15,15">
<Grid x:Name="PART_ContentSiteGrid" />
