Pls see screenshots, what I would like is for the pie chart just to resize to fit into the window. I currently have a piechart sitting inside a stack panel sitting inside a DockManager Content pane.
I have View3d=Tue plus the following transform
<Chart:XamChart.Transform3D> <Transform3DGroup> <ScaleTransform3D ScaleX="1.2" ScaleY="1.2" ScaleZ="1.2"/> <RotateTransform3D> <RotateTransform3D.Rotation> <AxisAngleRotation3D Angle="40" Axis="-0.961,0.27,0.06"/> </RotateTransform3D.Rotation> </RotateTransform3D> </Transform3DGroup> </Chart:XamChart.Transform3D>
I have tried playing around with the Scene/Margin types but with no luck
Can anyone help me out? thanks
Unfortunately not
Hello Chris,
This often happens when using winrar or winzip to extract a 7zip archive. Please double check if you can get the files using 7zip.
This file seems to be corrupt.
I am sorry about that. I reatached the sample project in my previous post.
I am looking forward to see hearing from you.
Think that solution is missing the LibraryBusinessLogic file
Chris
