660
How to sort grid by a certain field by custom sorting condition?
How to sort grid by a certain field using my own custom sorting condition?
For example I have:
1.  One DataView dv, that is binding for FieldLayout[0] of XamDataGrid grid
2.  Datatable1 of this dataView contains column "Id"
3.  Column "Id" is a foreign key for datatable1 and primary key of datatable2 4.  With converter's help I set "Name" instead "Id" in grid
<igDP:Field Name="Id" Label="Name" >
<igDP:Field.Settings>
<igDP:FieldSettings
AllowEdit="False"
CellValuePresenterStyle="{StaticResource CurrentStyle}"
CellMaxHeight="20"/>
</igDP:Field.Settings>
</igDP:Field>
class CurrentStyleConverter : IValueConverter
#region IValueConverter Members
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
if (value != null && (value is int || value is string))
return DataSet1.GetNameById((int)value);
if (value != null && value is DataRecord)
DataRecord dr = value as DataRecord;
if (dr != null && dr.DataItem != null && dr.DataItem is DataRow)
DataSet1.DataRow1 row = dr.DataItem
as DataSet1.DataRow1;return DataSet1.GetNameById(row.Id);
return value;
public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
throw new Exception("The method or operation is not implemented.");
#endregion
<local:CurrentStyleConverter x:Key="CurrentStyleConverter"/>
<Style x:Key="CurrentStyle" TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
<TextBlock
Text="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value, Converter={StaticResource CurrentStyleConverter}}"
VerticalAlignment="Center"
Foreground="#FF151C55"
Margin="5,0,0,0"/>
</ControlTemplate>
</Setter.Value> </Setter>
</Style>
As a result: sorting "by default" by "Id" column in grid:  is by "Id" field
I'd like, that sorting by "Id" column would make the grid sorted by Name assigned to each Id.
How can I easily do this?
Thanks for help.
