Hi there,
I'm having trouble binding a scatter chart to a xml file. If I set the DrawException property to false it works fine, butsetting it to true gives the following exception, which also cause it not to work in Blend:
"The scatter chart needs ValueX and ValueY. The values have to be set for every data point using ChartParameters collection."
My xml file looks like this:
<?xml version="1.0" encoding="utf-8" ?> <SERIES> <VALUE X="1" Y="1"/> <VALUE X="2" Y="2"/> <VALUE X="5" Y="3"/> <VALUE X="3" Y="4"/> <VALUE X="-1" Y="5"/> </SERIES>
XAML:
<Window.Resources> <XmlDataProvider x:Key="ScatterPlot" Source="Data/ScatterplotData.xml"/> </Window.Resources>...
<igCA:XamChart Name="XamChart2" DrawException="False"> <igCA:XamChart.Series> <igCA:Series Name="chart2" ChartType="Scatter" DataSource="{Binding Source={StaticResource ScatterPlot} , XPath = /SERIES}" DataMapping="ValueX=X;ValueY=Y" > </igCA:Series> </igCA:XamChart.Series> </igCA:XamChart>
Same thing works fine for column charts etc
ok, glad it worked out.
in the future, if you want to attach files to forum posts, switch to the "options" tab while composing a message and click the "add/update" button under "file attachment" on that tab.
I'm using VS2008 and it works runtime , but not at design time.
The version of blend we're using is Blend 2 Beta February or something along those lines.Where can I send that sample solution? In the meantime I'll get our designer to update Blend to the March preview.
Edit: I just installed blend myself ( the latest release) and it works fine there, and to be honest I dont care too muchif it works in VS at design time.
this works fine for me at design-time and run-time in visual studio 2008, and in blend march 2008 preview. i'm not sure if you indicated whether or not this worked in VS2008 or only blend. do i need to test it out in blend v1? or maybe you could send a sample project, as i am not getting the same error you are.
