we're using the xamRibbonWindow. When we're using it inside a RDP Session, the minimize Button in the title bar isn't visible. Right click -> minimize works though.
Regards,Patrick
NetAdvantage WPF 2010 Vol. 3
We just upgraded to 2011.1 and will check if this problem remains. I'll post the result (and more details if still necessary) here later.
Can you let me know a little more about your environment so that I can try and reproduce the issue. For example what operating system(s) are you using? Is there anything special about your remote session?
Valerie
We're using 10.3.20103.1003 (.NET 4)
I can't reproduce this issue with xamRibbonWindow. Which is the exact version of 10.3 that you are using?
Anastas
