1230
xamDataGrid ValueConverter Parameter How Do I Do It
I have asked this in a past post, how would I pass the active DataRecord to the ValueConveter class using the COnverterParameter object.  I have attached a sample project.
There are two numeric fields in the DataRecord - NumericVaue1 and NumericValue2.  The ValueConverter I created will change the Foreground color of the NumericValue2 field.
If NumericValue2 > NumericValue1 Then Foreground color = Red
If NumericValue2 < NumericValue1 Then Foreground color = Green
If NumericValue 2 = NumericValue1 Then Foreground color = Black
I need the DataRecord to access NumericValue1 when applying the ValueConverter to NumericValue2.  I get only the value of NumericValue2 passed to the ValueConverter class.  There are other cases I need the DataRecord in the ValueConverter class to do similar comparisons on more than 1 field.
I even created a Dependancy Property in the ValueConverter class to try and bind the DataRecord but no luck.
I hope you can help. Thanks, Bob
InfragisticsSample.zip
