We get this exception while calling [UpdateLayout] on charts in multi UI threads
at System.Windows.Threading.Dispatcher.VerifyAccess()
at System.Windows.Threading.DispatcherObject.VerifyAccess()
at System.Windows.FrameworkTemplate.Seal()
at System.Windows.Controls.ContentPresenter.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
at System.Windows.Controls.ContentPresenter.EnsureTemplate()
at System.Windows.Controls.ContentPresenter.OnPreApplyTemplate()
at System.Windows.FrameworkElement.ApplyTemplate()
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
at System.Windows.Controls.Control.MeasureOverride(Size constraint)
at Infragistics.Controls.Charts.NumericMarkerManager.Render(IDictionary`2 markers)
at Infragistics.Controls.Charts.ScatterBase.RenderFrame(ScatterFrame frame)
at Infragistics.Controls.Charts.ScatterLineSeries.RenderFrame(ScatterFrame frame)
at Infragistics.Controls.Charts.ScatterBase.RenderSeries(Boolean animate)
at Infragistics.Controls.Charts.ScatterBase.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.ScatterLineSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.Series.<.ctor>b__4(Object o, PropertyUpdatedEventArgs e)
at Infragistics.Controls.Charts.Series.RaisePropertyChanged(String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.ScatterBase.set_YColumn(IFastItemColumn`1 value)
at Infragistics.Controls.Charts.Series.<.cctor>b__4e(DependencyObject sender, DependencyPropertyChangedEventArgs e)
at Infragistics.Controls.Charts.Series.set_FastItemsSource(FastItemsSource value)
at Infragistics.Controls.Charts.Series.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.MarkerSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.Series.<.cctor>b__4d(DependencyObject sender, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp)
at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.Activate(Object item)
at System.Windows.Data.BindingExpression.AttachToContext(AttachAttempt attempt)
at System.Windows.Data.BindingExpression.MS.Internal.Data.IDataBindEngineClient.AttachToContext(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Task.Run(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Run(Object arg)
at MS.Internal.Data.DataBindEngine.OnLayoutUpdated(Object sender, EventArgs e)
at System.Windows.ContextLayoutManager.fireLayoutUpdateEvent()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.UIElement.UpdateLayout()
This issue has been reported and logged in our issue tracking system. I will create a case and link to an existing issue, so when the service release is out you will be notified. The solution will also be posted here after the fix is released.
You will receive an email notification shortly. Feel free to reply if you have any questions.
Thank you,Sam
