335
Change default edit mode
Hello, i need to change the event used to put a cell into edit mode, by default it is a single click, setting property "CellClickAction" to "SelectCell" you can still edit using a doubleclick, i want to disable this behavior but mantain the possibility to edit the cell
For example I would need to use double click to execute a custom methods and edit a cell using another control like a button put in a close column, could someone tell me what i have to do?
Thanks in advance
Marco
  • 138253
    Hello Marco,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I suggest you look into this forum thread:
    http://blogs.infragistics.com/forums/t/6748.aspx
    where a similar issue like yours is discussed.
  • 335
    Could someone help me?
    Thank you
