This question was recently answered in a private support case, and I thought I'd share it here in the forums:
Q: How to style a cell background based on another cell value in XamDataGrid?A: A DataTrigger can be used to achieve this. The following example demonstrates highlighting the cell background of a given Field, based on the cell value in the first column that contains '1'.** Style definition:<Style x:Key="labelStyle" TargetType="{x:Type igDP:CellValuePresenter}"> <Style.Triggers> <DataTrigger Binding="{Binding Path=Cells[0].Value}" Value="1"> <Setter Property="Background" Value="Yellow"/> </DataTrigger> </Style.Triggers></Style>
** Field definition:<igDP:Field Name="Info" Label="INFO"> <igDP:Field.Settings> <igDP:FieldSettings CellValuePresenterStyle="{StaticResource labelStyle}"/> </igDP:Field.Settings></igDP:Field>
