305
Change the style of the DataRecordPresenter
I want to give some rows a special style. I don't want to show the columns but only a label displaying some information. I prefer not to use different FieldLayouts, but only one FieldLayout.
I have styled the DataRecordPresenter and I am using a Trigger to style only the specials rows. At first this looks to work fine, but when I change my datasource by setting a new List, the styles are shown on other rows too. If I look closer, this is caused because the XamDataGrid re-uses the rows for other data, but the template is not removed. Is it possible to disable this, or are there other ways to accomplish this without multiple FieldLayouts?
Below a screenshot and the XAML. I have also attached a sample project to reproduce this.
Thanks!
            <igDP:XamDataGrid DataSource="{Binding CurrentCollection}">
                <igDP:XamDataGrid.FieldLayoutSettings>
                    <igDP:FieldLayoutSettings AutoGenerateFields="False">
                        <igDP:FieldLayoutSettings.DataRecordPresenterStyle>
                            <Style TargetType="{x:Type igDP:DataRecordPresenter}" BasedOn="{StaticResource {x:Type igDP:DataRecordPresenter}}">
                                <Style.Triggers>
                                    <DataTrigger Binding="{Binding DataItem.Description}" Value="Special">
                                        <Setter Property="TemplateGridView">
                                            <Setter.Value>
                                                <ControlTemplate TargetType="{x:Type Control}">
                                                    <igDP:DataRecordCellArea>
                                                        <Label Content="{Binding DataItem.Description}" HorizontalAlignment="Center" FontWeight="Bold"/>
                                                    </igDP:DataRecordCellArea>
                                                </ControlTemplate>
                                            </Setter.Value>
                                        </Setter>
                                    </DataTrigger>
                                </Style.Triggers>
                            </Style>
                        </igDP:FieldLayoutSettings.DataRecordPresenterStyle>
                    </igDP:FieldLayoutSettings>
                </igDP:XamDataGrid.FieldLayoutSettings>
                <igDP:XamDataGrid.FieldLayouts>
                    <igDP:FieldLayout>
                        <igDP:UnboundField Binding="{Binding Code}" Label="Code"/>
                        <igDP:UnboundField Binding="{Binding Description}" Label="Description"/>
                    </igDP:FieldLayout>
                </igDP:XamDataGrid.FieldLayouts>
            </igDP:XamDataGrid>
Testapp.zip
