1240
CellWidthResolved throws Exception
When shutting down our control, we are calling CellWidthResolved to save off some cell information.  However, it is throwing an exception.  Here is the stack trace:
   at System.Windows.Data.BindingExpression.Deactivate()
   at System.Windows.Data.BindingExpression.DetachOverride()
   at System.Windows.Data.BindingExpressionBase.Detach()
   at System.Windows.StyleHelper.ReleaseInstanceDataForTriggerBinding(BindingBase binding, HybridDictionary instanceValues, EventHandler`1 handler)
   at System.Windows.StyleHelper.ReleaseInstanceDataForDataTriggers(UncommonField`1 dataField, HybridDictionary instanceValues, Style oldStyle, FrameworkTemplate oldFrameworkTemplate)
   at System.Windows.StyleHelper.ReleaseInstanceData(UncommonField`1 dataField, DependencyObject container, FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, FrameworkTemplate oldFrameworkTemplate, InternalFlags hasGeneratedSubTreeFlag)
   at System.Windows.StyleHelper.UpdateInstanceData(UncommonField`1 dataField, FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, FrameworkTemplate oldFrameworkTemplate, FrameworkTemplate newFrameworkTemplate, InternalFlags hasGeneratedSubTreeFlag)
   at System.Windows.StyleHelper.DoTemplateInvalidations(FrameworkElement feContainer, FrameworkTemplate oldFrameworkTemplate)
   at System.Windows.Controls.Control.OnTemplateChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.RecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.DataRecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp)
   at System.Windows.StyleHelper.InvalidateContainerDependents(DependencyObject container, FrugalStructList`1& exclusionContainerDependents, FrugalStructList`1& oldContainerDependents, FrugalStructList`1& newContainerDependents)
   at System.Windows.StyleHelper.DoStyleInvalidations(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle)
   at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache)
   at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at System.Windows.FrameworkElement.set_Style(Style value)
   at Infragistics.Windows.Helpers.StyleSelectorHelperBase.InvalidateStyle()
   at Infragistics.Windows.DataPresenter.RecordPresenter.PrepareContainerForItem(Object item, Boolean isUsedForHeaderOnly)
   at Infragistics.Windows.DataPresenter.RecordPresenter.PrepareContainerForItem(Object item)
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeCachedCellArea()
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.VerifyCache()
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.GetCellValuePresenter(Field field, Boolean createIfNull)
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.GetCellValuePresenterDesiredSize(Field field, Size& size)
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.GetCellValuePresenterHeight(Field field)
   at Infragistics.Windows.DataPresenter.Field.GetDefaultHeight(Boolean isLabel)
   at Infragistics.Windows.DataPresenter.Field.GetCellHeightResolvedHelper(Boolean provideDefault)
   at Infragistics.Windows.DataPresenter.FieldLayoutItemBase.GetDefaultCellSize(LayoutItemSize size, Field field)
   at Infragistics.Windows.DataPresenter.FieldLayoutItem.GetDefaultSize(LayoutItemSize size)
   at Infragistics.Windows.DataPresenter.FieldLayoutItem.VerifyVersionImpl(Int32 fieldVersion)
   at Infragistics.Windows.DataPresenter.FieldLayoutItem.VerifyVersion()
   at Infragistics.Windows.DataPresenter.FieldLayoutItem.GetVisibility()
   at Infragistics.Windows.DataPresenter.LayoutItem.Infragistics.Controls.Layouts.Primitives.ILayoutItem.get_Visibility()
   at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.GetGridBagCacheHelper(GridBagConstraintCache[]& tmpGccArr)
   at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.CalculateGridBagLayout()
   at Infragistics.Controls.Layouts.Primitives.GridBagLayoutManager.CalculatePreferredSize(ILayoutContainer container, Object containerContext)
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.GetTemplateItemSize(Field field, Boolean isHeader)
   at Infragistics.Windows.DataPresenter.Field.get_CellWidthResolved()
   at RCS.Bengal.UI.MediaLibrary.MediaLibraryControl.<>c__DisplayClass3d.<SetGridColumnCollection>b__37() in C:\RCS_Source\main\Bengal\vs2008\RCS.Bengal.UI\MediaLibrary\MediaLibraryControl.cs:line 1881
I noticed that there is a CellWidthResolvedInteral value, but it’s private.  Is there any way to avoid this exception without just placing a try/catch around the call?
Dan
Parents Reply Children
No Data
