Hi
We are facing a very very strange behavior. Grid loosing Sorting & Grouping functionality after 15 to 20 minutes. Closing & opening the screen works fine. Then after 15 mins sorting is last. No clue why it is happening. Any idea what could be the problem.
This issue has been high priority issue b'couse screen is in production..
We are using Dataview as DataSource. which is binding to xamdataGrid.
Pls help me asap
thanks
-Kiran
forget to mention the version It is 10.1
The data in the datatable is dynamic. It is constantly deleted & added dynamically but the binding is not removed. Data is added on the GUI thread only.
Pls let me know anything I can ivestigate
HI Kiran,
Can you give me more details regarding your application.
Is your DataTable being updated dynamically? Is it possible that your datasource is being changed by some background process?
What build are you using?
Sincerely, MattDeveloper Support Engineer
