I've dug around the forums but haven't had much luck in finding any information related to this. We use the WPF XamDataChart to gather incoming data and are trying to find a way to have two sets of marked points. I haven't found a lot of information in the
First set: These are makers that reside on the axis line. Their purpose is to mark a point in time that some event happened. These are placed by users clicking a button elsewhere. This happens as the chart is being updated.
Second set: These are markers that reside on a chosen series. They are points selected by a user, and are placed via clicking on a line at a given point.
My best guess as to how to implement this is to simply create a secondary set series that are scatter-point series that has some overhead logic to plot the points. But if there is a simpler way (or any way, in the case of binding a marker to the axis) I would love to see! Thanks!
how can i render the selected point in different color for scatterpointseries ?
Do u guys have any idea ??
Oh, I see! That did it, and was exactly what I was looking for, thank you so much!
HI Collin,
You you can specify a legend for each series. So don't specify a legend for the series you create on the X-Axis.
Here is a link to Multiple Legends
http://help.infragistics.com/NetAdvantage/WPFDV/2010.3/CLR4.0/?page=xamDataChart_Multiple_Legends.html
Sincerely,
Matt DSE
Matt, that helps, thank you. It looks like to keep it on the axis line I'll have to bind to an event that gets raised when the bounds of the X axis change. Is the best event for this xamDataChart's LayoutUpdated or is there a better event to hook into?
The only question I have left then is how to have a legend, without the "marker" (the axis series) series from showing up in the legend. It appears that the legend can get children instances and from there I could find and set the marker series' visibility to collapsed, but your documentation says the children shouldn't be touched. Is there a better way that I'm not seeing?
Again, thank you for the help Matt, I really appreciate it.
HI,
I am attaching another project that adds a series via button click so the points show on the X-Axis.
Sincerely, Matt Developer Support Engineer
