225
How To: Get column header text for a hierarchy linked to data cell double-click
I worked through the docs/sample code and couldn't seem to figure this out. He have a use case where a user clicks into a cell and we generate something that uses the column header. Here is the scenario:
When the user double-clicks the 143,762,200 cell I use the MSFT part of the hierarchy to indicate what kind of action to do next and then use the BCY field as a field in that action.
Here is where I am:
   var xcell = pivotGrid.SelectionSettings.SelectedCells.FirstOrDefault();
This gives me the cell however there seems to be no easy way to get the correlated column header parts. I poked around in the DataColumn and DataRow to no avail.
Thanks,Damon
  • 7922
    Suggested Answer
    Hi Damon,
    Below is a snippet how to find the members for column and row hierarchies.
    private void pivotGrid_CellClicked(object sender, PivotCellClickedEventArgs e)
        // find cell location
        int columnIndex = pivotGrid.DataColumns.IndexOf(xcell);
        int rowIndex = pivotGrid.DataRows.IndexOf(xcell);
        // extract the tuples
        ITuple columnTuple = pivotGrid.DataSource.Result.ColumnAxis.Tuples[columnIndex];
        ITuple rowTuple = pivotGrid.DataSource.Result.RowAxis.Tuples[rowIndex];
        // accordance between members and hierarchy
        // columnTuple.Members[i] = pivotGrid.DataSource.Columns[i];
        // from members list you can find the hierarchy
        IDimension dimension = columnTuple.Members[0].ParentLevel.ParentHierarchy.ParentDimension;
    Regards
    Todor
