490
Marker Text cutting off Y axis label
We are running into the issue where marker text is not visible for certain cases. We tried setting maximum and minimum value on NumericYAXis, but in that case, intervals gets messed up and I was wondering if there any other work around to resolve this issue
  • 7305
    Suggested Answer
    Subhash,
    It seems like the Maximum range is not big enough to give room for the markers. Does you application limit to increase the maximum range?  or maybe you can show the markers inside the column.
    Can you give me a little more information as to what your requirements and expections are and I will see what we can do based on that information?
    Thank you,
    Sam
