I have WPF application which is using xamChart with Any CPU compilation does not work /
Display 3D charts on 64bit machines. but, yes it displays 2d charts (View3D =false)
Can some one help in this regards.
Thanks in advance.
Narayan
I tried searching the MSDN site for solutions for this issue but didn’t find any. As I mentioned before, this is a general problem with WPF on Windows Server2003 64 bit processors, not specific to our controls.
Let me know if there is more I can help with.
What is the resolution to the existing issue?
After reviewing this issue with our development staff, this appears to be a general problem with WPF on Windows Server 2003 64 bit processors. The behavior is evident with other 3D xamChart types and also using 3D controls other than our xamChart.
I could not replied to the case created based on our request case no. .CAS-62175-ZNBFHS.
Can you please reply to the following info they asked in that.
Question asked : dev environment
Ans : Windows xp proffessional 2002 SP3, Intel core 2 due cpu, E6550 @ 2.33Ghz.
Did you get a chance to try other 3D chart types? Or is this behavior only for the 3D Pie chart?
Narayan Comment: I tried with other 3D charts (Bar, Column) and is the same behavior
Are you using the same NetAdvantage 2009 Vol. 2 service release version that I am using?
Narayan Comment : Infragistics3.Wpf.v9.2.20092.1007 - we are using
Is this behavior only visible on your deployment machine or also in development?
Narayan Comment: I was getting this behavior on deployment machine then, I installed VS 2008 on deployment machine and tried but, the same behavior (not display's 3D charts)
Machine details : Windows Server 2003 R2 , Xeon , 64 bit
