Hi,I am using a XamPivotGrid with its datasource's itemsource bound to a collection of some custom object. I then define rows, columns, measures and hierarchies. Let's say for example, I add a field "Month" to the Columns collection. In the resulting Pivotgrid, I get Month values as columns in any random order. Instead of Jan, Feb, Mar and so on, I get Dec, Feb, Sep, May, etc. Is there a way to sort the columns themselves?Thanks,DA
So has this feature been implemented? If so, how can I use it? How can I generally specify the order of columns when reading from a flat datasource?
Hi
The release was posponded for first or second week of June.
RegardsTodor
Is there any follow up to this? I would think for most users this is a critical feature.
I am just checking if you still require any information or clarification on the matter.
Sincerely,DimiDeveloper Support Engineer, MCPD Infragistics, Inc.www.infragistics.com/support
This is a issue we fixed in 11.1 release. It will be available in April this year.
Regards
Todor
