I'll start off by saying that I'm still new to WPF and even more so Infragistics...so bare with me.
I have a XamDataGrid and I want to add a ComboBox to the add row for a specific column. We have a collection of Strings (in List<String>) that I want to display in the combo box. I've seen a lot of examples that show to use a ComboBoxItemProvider but not sure if this is the correct / only way to load the data in the ComboBox. Also, I want to set the binding all in the xaml and not in the code behind.
Are there any examples on how to do this? Or any idea?
HI, I am just following up on this forum thread.
Plesae let me know if you need further assistance.
Sincerely, Matt Developer Support Engineer
HI,
I am attaching a sample application that embeds a XamComboEditor inside of a XamDataGrid Field.
Please review my sample.
Sincerely, Matt Developer Support Engineer.
Sorry - put the wrong piece of logic... I have the wrong binding source statement...
<igDP:UnboundField Name="ConditionName" Label="Condition Name" Visibility="Visible"> <igDP:Field.Settings> <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}" EditAsType="{x:Type igEditors:XamComboEditor}"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="ItemsProvider"> <Setter.Value> <igEditors:ComboBoxItemsProvider ItemsSource="{Binding Source=MatchedSecondApprovalCollectionView}" DisplayMemberPath="RuleName.DataValue"
/> <!--ValuePath="RuleId.DataValue"--> </Setter.Value> </Setter> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings></igDP:UnboundField>
Tried to simplify some of the coding into this...but does not seem to work. In my drop down I get nothing but blank rows..
<igDP:UnboundField Name="ConditionName" Label="Condition Name" Visibility="Visible"> <igDP:Field.Settings> <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}" EditAsType="{x:Type igEditors:XamComboEditor}"> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamComboEditor}"> <Setter Property="ItemsProvider"> <Setter.Value> <igEditors:ComboBoxItemsProvider ItemsSource="{Binding Source={DynamicResource MatchedSecondApprovalCollectionView}}" DisplayMemberPath="RuleName.DataValue" ValuePath="RuleId.DataValue" /> </Setter.Value> </Setter> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings></igDP:UnboundField>
Any help is greatly appreciated!!
If you want to do everything in xaml the ComboBoxitem provider is a good way to go.
Here a help link on using XamComboEditior to Edit a Field in XamDataGrid
http://help.infragistics.com/NetAdvantage/WPF/2010.3/CLR4.0/?page=xamComboEditor_Using_xamComboEditor_to_Edit_a_Field_in_xamDataGrid.html
Sincerely
Matt
