285
Correct way to programitically move a column/field
Hi, I have an anoying problem with the XamDataGrid and moving of fields. The problem is quite simple, under certian circumstances (external to the grid) I want to make two fields visable and move them to column positions 0 and 1. So I do the following, {grid}.FieldLayouts[ 0 ].Fields.Move( i , newPosition );
This works fine except when the user has rearanged the columns manually in which case normally my columns are already in the correct position but the actualPosition poins to a different location. Thus what is the correct way to programatically move a column so it works under both scenarios? I hate the actual position attribute as it's flakey exspecially if you hide a column (you get several columns at position x which makes life very difficult).
thanks
Muumi
  • 138253
    Hello Muumi,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking through your post and I suggest you set each Field’s ActualPosition Property, but note that this won’t change the Index if the Field in the Fields Collection, only its position in the FieldLayout.
